FnFilthy
I made a huge and amazingly stupid mistake. As I was assembling my new engine, I carefully removed a sensor at a time from the old motor and installed it in the same location in the new motor. Somewhere along the line (after pausing over night) i had turned one of the motors around. Now I have Sensors in places they shouldn't be. This is made even worse as this was an ambulance which had dual heater cores and other gadgets.
I have a 1992 E350 IDI and I just need to know where heater hose nipples and specific sensors/plugs go into the heads. I've got the easy stuff (the rear oil sensor, glow plugs, injectors), I just have a helluva lotta holes in the block and head.
This would be a tremendous help. Obviously I can sort of figure things out based upon the wiring loom and hose locations, but I would like to make certain I get it absolutely right.
Thank you so very much.
