1992 F-250 Lighting Problems...
firemedicmonkey
Erie Surf and Ski
Oh-io via TX and LA
So I just picked up my third IDI... Since my other two are down still...
I brought this thing home and the tail lights are not working.... I checked the bulbs they are fine. There is no power going back there. I checked the fuses under the dash they are all good. Any ideas on where to start?
Also the turn signals are not working. Neither left nor right works. However the 4-ways work... I am thinking that the multifunction lever is messed up... Any ideas of where to start on this?
88beast
pa
well i got similar taillights go in and out and brake lights dont work at all
ive been trouble shooting on warm days
so far i found power to the switch and multi function switch but no power to bulbs when it gets warmer im checking between them
firemedicmonkey
Erie Surf and Ski
Oh-io via TX and LA
I checked all the fuses in both under the dash and under the hood... I also replaced the multifunction switch with a known good one... No change... Anyone know what wires are used for these circuits tails, and turns...
91idi
Fiberglass *****
X
check the turn signal switch. That fixed mine
flareside_thun
Reviving The General Tao
Tavares, Florida
On his year the multi-function switch replaces the turn signal switch...basically the equivalent...but with more stuff.
f-two-fiddy
Duluth, Mn.
First, take a look out back. I'd almost bet there's a rats nest under the truck where PO has tried to tie in a trailer connex. If You see ANY of those suitcase connectors, You've found one of Your problems.
