Yep. You rebuilding the trans? Or a shop doing it?
May as well do head studs if it's out and getting a turbo. A friend of mine is doing a similar swap, just don't have the donor truck for wiring and whatnot. It's a 90 F350 CCLB 4x4 460/E40D getting a 6.9/E40D.
224-3509HA is discontinued. (this is the hard anodized crown piston that would fit non IDIT 7.3's, 0.020" decompressed aswell.)
The turbo would end up burning up this piston. (edited out) from tech said the parts below would work but we do not advise doing what your customer wants to do. There would be no warranty if you went this route but the parts below are what you would use. If any questions, call (Edited out)
8 2243512HAWR (these are IDIT pistons. Hard Anodised crown. standard compression, I would have to change my connecting rods and have the harmonic balancer and fly wheel rebalanced and the very least)
8 CB1327P (rod bearings)
1 MS1596P (main bearings)
1 953299VR (complete victor reinze gasket set)
