kronby
Hello, I recently bought an E350. drove it home everything worked great. Let it sit for a while and it would not start. Decided it was the glow plugs so I replaced them all and it fired right up. However, upon getting it started it will not go into gear. I can move the shift lever into each position but it seems to remain in park. Looking under the van I can see that the shift lever is relaying action to the transmission, but nothing is happening. Transmission worked fine before. Brake lights work, front turn signals work, rear turn signals do not work, and hazards do not work. I was wondering if it was likely some sort of electrical issue, or if it was a mechanical issue with the transmission. Transmission is a e4Od, engine is 7.3 idi. Any help is appreciated, thanks
