VandalS
I've got my 1986 F-250 with the stock cluster (speed, tach, water, oil, volts, fuel). I'm planning to turbo it soon and will be adding a boost/pyro gauge (either 2 gauges or a combo) and have space where the radio was, but I'm considering putting in all new gauges and fitting the gauges with the following in place of the stock cluster:
3 3/8"
-Speedo
2 1/16"
-Boost/pyro combo
-Fuel
-Oil pressure
-Water temp
-volts
Is the stock cluster gauges bad enough to require replacement if all of the gauges still function? This is about 450.00 for all gauges other than boost/pyro. My thought on placement is to put speedo to the left and the other 6 gauges in 2 rows x 3 columns. Is there a gauge I'm missing that would be useful to have?
3 3/8"
-Speedo
2 1/16"
-Boost/pyro combo
-Fuel
-Oil pressure
-Water temp
-volts
