Hello Fellow IDI Junkies.. Im fairly recent to the IDI world but did acquire a 86 6.9 F250 Extended Cab, 4x4, C6 Auto with 49K showing on the Clock (PO said it rolled once, Who knows?) I was actually gonna sell this truck and have been driving it around lately and decided to keep it. The Other day I noticed that the Upper Radiator hose was swelled up (engine Running) and was extremely difficult to compress. The 1st that came to mind was Head Gasket, So I shut it down, Let it cool down and grabbed my "Combustion Gas Checking Tool". Started it back up, Waited for things to start circulating and without a doubt It turned the special dye Bright Green when I pumped the bulb, Which per the instructions = combustion gasses. After doing some Research im leaning towards just pulling the Motor to complete the Task and Now im just wondering how far I should take it.. Complete Rebuild? I haven't noticed any tell tale water signs in the oil Cap nor any water/Mixture showing on the Dipstick, I haven't done a oil change (which would probably shed a little light). The Oil pressure gauge has always showed a little low, My plan is to get a compression check of all the Cylinders (already have the Gauge with proper glow plug attachment) and getting a secondary oil pressure reading from the actual Port. Is there anything else I can do that would aid me in determining the Engine Condition or help me make a decision on how far to take the Rebuild? Anything I should do prior to pulling it?
Again im fairly New to the IDI world but have learned quite a bit from past posts, So Please bare with me if im asking redundant or Silly Questions.
Thanks
Thanks
