1984 7.3 powerstroke build
If you haven't decided on a sealant yet, I'd suggest windshield sealer. I'd think that would work.
goldsjos18
wisconsin
Well today I got the holes drilled for the transmission cross member. Front drive shaft and sent out the rear axel for sandblasting and paint. Also I got the firewall from the 94 donor truck out I will start cutting out the fire wall in the 84 on Saturday
Cruiseomatic
Defining Insanity
Dark side of the Sun.
So basically the only difference in the single and split window is mounting bolt locations? Sounds easy enough but what about the interior panels? What do you do about those?
goldsjos18
wisconsin
im actualy going to use the interior form the 94 inside the 84 dash, panels, doors , windows
goldsjos18
wisconsin
I got the fire wall installed today just finishing up welding it all on the out side top going to weld on the inside bottom
It wouldn't be if I wrote it. I think it's fascinating and am enjoying reading it.
goldsjos18
wisconsin
Sorry guys this if my first thread on a build series never done one like this before...
goldsjos18
wisconsin
Well didn't do much today as it was rainy but I did get the trans cross member bolted in
olsen726
