18.4 MPG!
chris142
SoCal
You need a fan if you want ac. Mine Is absolutely fridged.
Cubey
Van dweller
USA
Damn. I get excited when I break 14.
I can get 14-15 easy in my F250 (see sig). It honestly seems to get better mpg at 60-65 than 50-55.
The RV gets about 9.5 hwy mpg at 55mph. It has a 4.10 dually and ATS 085, while the F250 is 3.55 srw and NA. The F250 got exactly 10mpg hwy pulling an old 27ft trailer that was shorter than this RV is. Both are 6.9/C6 RWD.
So for what this RV is, it does pretty darn good.
david85
Campbell River, B.C.
I haven't seen above 13 for a very long time. My truck has been used as a daily on a 4 mile trip to and from work. And with a good 10min of idling before taking off. Warmup period combined with an urban driving loop is brutal.
  • Like
Reactions: Clb
Slicknik
Burbank, CA
I’m getting 18-19 empty with my 7.3 CC IDIT but I’m 2wd and 3.55 , E40D trans
1900ft
265/70/17
6500 empty (1/2 tank)
Loaded (10-12k total) I get 14 mpg at 60
Cactus Bob
STRAWBERRY, ARIZONA
19.3MPG 92 E350 auto, extended body..All in town miles no hwy miles. loaded down with tools. but driven like i was hypermileing all the time.
Edit per clb's request below :
Altitude : 1124 ft
Cgvw : weight? i am guessing ? unknown but it's an E350 extended with approx 3000 lbs of tools and parts.
Unladen weight: ? i have no idea what this is.
Grade pulled: no grade Phoenix area is flat.
Tires : regular 1 ton 2wd van tires with road thread
Mileage :Body 167,000 miles, Engine 20,000 miles on rebuilt engine, 20,000 miles on rebuilt transmission.
injection pump NOS 20K ago and new NOS injectors 20K ago
carsonlhammond
Jackson, CA
when I was n/a I was getting 15-18 mpg depending on how much WMO was in it and how the girlfriend was acting that daycookoo I have yet to drive it with the h1c.
nelstomlinson
Delta Junction AK
I'm not, but I live in Calgary Alberta, north of the 49th parallel. At my brother's farm, about 4 hours north, he had ice in the bird bath this morning!
What is up with you Southerners?! Calgary is only 51 degrees North, and it's freezing? I'm at 64 degrees North and we haven't had frost in weeks!
Clb
Another old truck
nannyfornia
Ok enough b.s ing facestylebook...
Post these parameters up....
Altitude
Cgvw
Unladen weight
Grade pulled
TIRE SIZE IN ACTUAL USA. INCHES. (Are you smaller than stock???)
My best with a stock eng. Stock tires, 37k factory odometer, and a light foot was, With an ats 093 aftermarket market turbo... Runnin I5 in cal up the grapevine at 3-5 psi was 14; best of luck pullin at +9......
School me I need mpg BAD
odemeter calibration
Thewespaul
Bulverde, Texas
1400ft
6800lbs
Zf5/3.55s
33” tires
287k miles
17 mpg regular driving, best 23 on highway in perfect conditions. 15-16 towing.
Macrobb
North Idaho
I'm averaging, these days about 14-15 tank-to-tank. Lots of 10-mile cold trips hurt the mileage, longer trips unloaded help.
This is with 4x4, worn IDIT, stock IP cranked to the moon, Factory turbo, 4.10s ZF5, GV OD. Weight around 6600lbs.
Speeds usually 64 to 75 on the highway(depending on speed limit).
I've gotten as low as 10-11 on a tank before, hauling hay. Usually, towing is a smaller part of my tank, so even if I get 8-9 during that stretch, the tank average is higher.
carsonlhammond
Jackson, CA
6.9 typ4 cam fuel advanced and turned up 1 flat, NA, Zf5 close ratio, 4.10's, 35in. mud terrains.
300-1100 ALT.
5340lbs with tools, gen poles, half tank(17gallon)
16 around the county on backroads (mostly what it sees)
18 on the highway
towing 25k total vehicle weight 12-14 on backroads. haven't taken it to the highway yet.
measured over 3 tanks using gps. on an average of 50/50 wmo and diesel
400-1100(no more then 5 seconds)
nelstomlinson
Delta Junction AK
With my '87 6.9IDI with a Banks, I get about 15MPG around town, and up to 17MPG on the highway if I hold it to 55MPH. With my '89 crew cab, I get about the same. Stock tires on everything.
Edited to add, my altitude is about 400 to 1200 feet.
