87crewdually
I haven't tore into it yet but my friends truck quit moving the other day when he sat in traffic. It was pushed into a lot until this morning. To sum it up no matter where you move the t-case lever the thing is stuck in 4x4 Lo. Also I noticed the front shaft will turn about 180* before it fetches up. This tells me it's in 4x4 and the chain is stretched, alot. It is possible to be low on fluid too since i noticed a leak and I think someone was runnin on the high way in
4-wheel. (just a hunch)
Are the manual and e4od tcases the same? Anyone run into this before?
Oh yeah today was the maiden voyage towing with the head gaskets finally solved I hope. egt's topped at 950 12psi boost and a whole lot of watching the temp gauge (keeping my foot out of it). Only once I worried when temp went up but settled right down once up to speed with the cruise set in O/D. No degrees but my gauge is consistent and running flat empty it's between the "n" & "o". When it went up today it peaked between "m" & "a" in normal. When I got home I checked the temp at the top of the radiator it was at 195*.
