12v cummins swap experiences
pennsylvaniabo
pennsylvania
HX35's, found on 94-98 12v cummins. These motors are 5.9l in displacement, and turn a factory 3000rpm's. Stock 12 valve boost 18-20psi
TP38's, found on 94-97 OBS PSD's. Motors are 7.3l and spin 3800 rpm's. Stock boost 15-18psi
If your going to go through the trouble of retrofitting a different turbo, I would only recomend going with something that comes for a like motor. The TP38 flows a lot more than an HX35.
Not saying the HX isnt a good idea, but stock for stock, an OBS or superduty 7.3 PSD would work better as it was designed for an engine with almost the same (or the same) displacement, and the same rpm's.
You can spend $300 on an HX35, or $300 on a TP38. HX35 has much more options than a TP38 as far as aftermarket is concerned, but stock for stock the TP38 flows much more.
But will a PSD turbo work? As long as it has a t3 flange....i can fab an intake hat.
MIDNIGHT RIDER
We need to get 444IDI's thread back on it's intended track.
He can worry about turbos long after the engine is installed.
93_444idi
first on race day
missouri
digging up an old topic. is there a certain 90* manifold that I need? a guy nearby is selling a 90* manifold and turbo off a cummins 8.3. he said he sold it once and the guy sold it back to him because it didn't fit his 5.9. will an 8.3 manifold not work? i'd like to just go to a dodge dealership and quote a new one, but I dont know what kind of truck it needs to come off of.
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
From what I have looked into the Manifold that works best looks like mine:
However they didn't come out of the Dodge Cummins, They were out of the industrial applications,..buses, big trucks etc. So I really cant help you more than that. I know that Midnight Rider found one ant installed it on his truck but not sure where he found his.
MIDNIGHT RIDER
My exhaust manifold is identical to Darrin's, in fact I studied his pictures a thousand times in my quest for one.
The 8.3 manifold is for a larger series engine, "C"-series I think; whereas, the 5.9 is a "B"-series, as in 3B, 4B, 6B, and even 8B, all sharing identical cylinders, valves, bearings, and such; there may even be a 2B.
Add a "T" for turbo and the 5.9 is a 6BT
;Sweet
mobilemech
Redding CA.
Get a A/C mount from a Case 580 backhoe or a 570 skip loader, they use the 4bt engines but the A/C comp. is mounted up next to the head. for those who have limited fab skills or lack of time.
adamg
granville ma
i just used fordcummins motor mounts and have no clearance issues with ac compressor rear valvecover or turbo. worst thing i ran into was not having enough room for hood latch with second gen intercooler. i hate body lifts so hood pins will do :eek:
highfive
Oregon
got any underhood pics? what type of exhaust manifold is on the motor and how close is the turbo to the heater box?
thanks
ntjapkes
