Turbo---CFM----Racing HP-----Daily HP inducer
HX35----574------420----------330------ 56
HX40----763------560----------440------60
TP38-----767
T66------800-------560----------440-----66
GTP38R--897
B1/S300--900-------630----------495-----62
H2E------868------700----------550------63
HX50----1000-----700-----------550-----63,67
HX55----1050------735----------578-----67
HT3B----1085------770----------605-----76
GT42----1302-----------------------------75
T76-----1350------945----------743------76
HT60----1400------980----------770-----76
B2/S400-1500------1050---------825-----75
GT47---------------------------------------80
HX60-----1550------1085-------853----
TV81----1600-----------------------------85
T88------1750-------1225--------963-----88
HT4B-----1800------1260---------990-----88
Big Brother-1900---1330--------1045-----87
T91-------2000------1400--------1100-----91
HC5A/HX82-2450----1715--------1348----95
T100------2600-----1820--------1430-----100
T105-----2900------2030--------1595-----105
HX35's, found on 94-98 12v cummins. These motors are 5.9l in displacement, and turn a factory 3000rpm's. Stock 12 valve boost 18-20psi
TP38's, found on 94-97 OBS PSD's. Motors are 7.3l and spin 3800 rpm's. Stock boost 15-18psi
If your going to go through the trouble of retrofitting a different turbo, I would only recomend going with something that comes for a like motor. The TP38 flows a lot more than an HX35.
Not saying the HX isnt a good idea, but stock for stock, an OBS or superduty 7.3 PSD would work better as it was designed for an engine with almost the same (or the same) displacement, and the same rpm's.
You can spend $300 on an HX35, or $300 on a TP38. HX35 has much more options than a TP38 as far as aftermarket is concerned, but stock for stock the TP38 flows much more.
