10.25 van rear
giezy
rockwood/on/Canada
have a van 10.25 here with disk brakes on it can i swap the brakes to my 95 250 or is the end of the housing different?
Fordman75
Lonsdale, MN
What year is the van rear diff? Are you sure it's a 10.25" and not a Dana 60?
If it's the Dana 60 from right around 99, 2000 then it's no where close to be a bolt on deal. But it can be done with some welding.;Sweet
This isn't my website but I found it when I was looking into doing this swap on one of my other projects.
http://www.fordmann.com/F350.rear_disc_brakes.htm
Double-S-Diesel
parts seller
derry pa
its possible its a d-70. the one I have is out of a 2000, thought it was a 10.25, looks danm near the same.
but there is a 70 on the pumpkin
but the good news it would work in a obs, all ya need to do is move the spring perches, the width is ok
Fordman75
Lonsdale, MN
If I understand it correctly the Dana 60 was the rear in the SRW E350 vans and the D70 was in the dually E350 vans.
IDIDieselJohn
0-60....eventually
Ottawa Ontario
Back when Ford was actually Built Ford Tough, all 1 ton vans had full floating D70 rear axles.
Now that it's Built Ford Tough with Some Cheap Chevy stuff, some E350's have semi floating D60's.
My '85 E350 has a Dana 70HD and my '87 E350 dually motorhome has a Dana 70U with slide off drums.
Any van rear end from any year 1975-current will be a direct bolt in deal, including the rim bolt pattern. The vans still uses our old bolt circle.
Easy way to tell a Dana from a Sterling.
The Dana's always have the fill plug in the differential cover.
The Sterling's all have it in the housing, facing the front on the drivers side.
Fordman75
Lonsdale, MN
This doesn't look like a semi floater to me!:D;Sweet
Not true. My Dana 70HD has the fill plug in the housing. Plus I have an aftermarket cover. The more I learn about variations in Dana axles, the more I realize each one is like a snowflake. LOL
Black dawg
sw mt
thats pretty crazy that it has a plug in the housing, I have NEVER seen a dana without a plug in the cover.
I also have a 70 (35spline) and the plug is in the cover.
IDIDieselJohn
0-60....eventually
Ottawa Ontario
Mel, that's news to me, never seen that either.
My '85 van has the D70HD and it's got the fill plug in the cover?
rhill5353
