I would like to change my gear ratios front and rear (4.10 to 3.55). I have a complete extra front end with the correct ratios and but to figure out what to do with the rear end. I was initially planning on just installing a new ring and pinion set, but am not sure I want to attempt it. Also I need to keep costs down as much as possible. I've worked on cars and trucks quite a lot (was a tech assistant for several years as I worked through high school/college), but never really got into any differential work. Any work would have to be done in my driveway, I have a decent set of hand tools and basic air tools. No specialty rear end tools though.
Being somewhat skittish about tearing into the rear end shortly before I need to leave on a trip, I start looking around for an entire rear end. I found one locally at a yard for about the same cost as a set of new gears ($275). Only issue is its an open diff (axle code 39). My current rear end is limited slip - would I be able to swap my LS unit in without messing with the gear lash etc?
I'm open to suggestions ideas etc. Keep in mind I have a limited budget and will be leaving for a trip to FL in a couple weeks. Would like to have it done before then, but not absolutely necessary. I'd also like to retain a limited slip rear and would like to think about adding a traction device to the front end before installing (lunch-box locker or LS??).
