rickstricks
- Joined
- Nov 13, 2007
- Posts
- 5
- Reaction score
- 0
I have an interesting problem I wanted to see if anyone could shed some light on. I recently purchased an 04 350 superduty and the factory trailer plug had been stolen. I finally got one for it, but when I hooked my trailer up all I get is running lights. Here's what I've checked thus far. I have a good ground at the 4 way and the 7 to the frame, I've got 12v running light power on the 4 and the 7, I've got the 12v constant on the 7 and 12v for trailer brakes on the 7. The relays under the steering wheel and the hood are all kicking on when the signals are on. And all associated fuses under the steering column are good. I only found one small 10amp fuse in the relay box under the hood and it was good also. I'm getting no power for signals or brakes back at either plug. If anyone has had this problem and was able to figure it out, I'd be very grateful to hear what you found. I've got a trip coming up in July and would sure like to resolve this beforehand without having to splice into my main wiring.
