93cc7.3
needs turbo power
hey i just picked one up do we have to use the optional adapted for this and which way do i install this
With a VOV , you can use a the charts as a rough guide at best. and yes, expect to see higher charge figures on the low side. These things change teh pressures around and teh balance in teh system is all haywire so normal charts are pretty worthless and going by temperature works best by charging till it wont get any colder. When teh system starts to reach an overcharge point it will begin to run warmer instead of colder. That is you balance point. Keep adding slowly and you will continue to get reduction in temps at the ducts . when teh duct temps stop dropping, stop adding, that simple
Is that on max cooling with fan on high? And what refrigerant?This is a person who has installed more than a few VOVs. He hit it right on the head. about how to charge on of these. In a normal vehicle with an expansion valve or normal orifice tube I charge by weight using a scale. Anytime I use a VOV in a vehicle just as RLDSL said keep bumping it till it starts to get a little warmer. I've got a couple small digital thermometers I'll stick in the ducts to keep checking till it starts to go up instead of down. My service truck right now in 105 degrees temps is blowing 38 degrees out of the vents.
