david85
Part rant, part brain storming session so bare with me
It seems I'm not the only one here that feels as though I hit a wall when it comes to getting enough boost to reach the full potential of these engines.
Banks, ATS, and Hypermax - junk! They just refuse to flow efficiently above 10 PSI because thats what all those companies determined is safe for this engine.
I am running a 60-1 compressor wheel on my 088 and while the butt dyno does confirm some better results, peak boost didn't really change by much. Fuel economy is acceptable but every time I start leaning on the throttle, the boost is always a good 2-3 PSI below ideal and it gets worse higher up in the throttle range no matter how much RPM I allow.
Twin turbos have been discussed before but so far no one has been able to build one and frankly, I don't think we should have to go through that kind of trouble to get into the high teens for efficient turbo boost.
Some guys have mentioned using a holset turbocharger off a cummins engine. Has anyone done this? Is there a garrett turbocharger combo that could compare?
Other then that, any and all ideas welcome on how to break into the 10-20 PSI range efficiently - that means without obscene amounts of smoke.
