Cheaper Jeeper
Anybody know what kind of temps home brew can handle without gelling up? And will standard anti-gel additives (PowerService 911 for example) work OK with home brewed bio?
I have run b50 in various diesels in the middle of winter with no issues...but I wouldn't go any more during that cold....but no problem in the warmer months of course.
I ran b100 in an LMM duramax without issue year round. That's Colorado year round..
That sounds good, but how much #2 are you mixing with your B100? Are you ending up with B90, B70, B50? or what?...just use some #2 fuel and Power service and B100 and drive.....
What part of CO? Like the previous poster, as far as I know, that could mean 20 degrees, or zero degrees, or 30 below - depending on where in CO....
More specifics please...
Northern Colorado. It's 12 degrees out this morning for example...
So B100 is good down to 12 degrees. Excellent data point. Is that home brew or commercial B100? No addatives, right?
Not trying to be vague, just a quick response, just mix the power service to directions, i'm running a 50/50 winter and 80/20 summer. but my avg temps are not that low. 59 right nowThat sounds good, but how much #2 are you mixing with your B100? Are you ending up with B90, B70, B50? or what?
Why is everyone being so vague?
