Doug Nash OD Box
jaluhn83
Upper Marlboro, MD
Very good condition DNE2 OD box. I think this was either rebuilt or new and basically never used. The shift collar and teeth are perfect, and everything internal looked very clean. Best I've seen out of the half dozen or so of these I've had apart.
Now, the bad news - this is a 32 spline input box originally off a Chevy TH400. I should fit a T-19/18, but I do not have the adapter for this. If someone out there has the adapter and wants a great condition overdrive to go with here's your solution, or if you need one for a chevy.... I was going to use this behind a 13-45 T-case but discovered that while both are 32 spline, the spline shapes are different so it wouldn't fit.
I do have the wiring and control for use with an automatic trans. Wiring for a manual is simple - just need any kind of SPDT switch.
Asking $750 obo.
tke395
