bigblockfever
I had a question about this transmission swap. We pulled the truck into the shop everything running but the zf. Pulled the zf and the bw 1356 out of the truck. Swapped in a 4spd (i forget if it was the t18 or the t19)and bw 1345. Would the flywheel and the clutch work from the zf to the 4 spd transmissions. If it won't then i think that is where we went wrong. Thanks.
truck is a 1987 ford f250 single cab. Has a 7.3l. Swapped out the 6.9 ages ago with the 4 spd.
