sle2115
NRA LIFE MEMBER
Has anyone ran Royal Purple Synchromax in their ZF5?
I was in the parts store picking up my flywheel and the oil rep was there. I asked him what he would run in a ZF5 for gear lube. He just so happens to have two ZF5 trucks and said he's been running it in them for years with VERY good luck, quiet operation, etc.
I'm going to run ATF first to clean things up (tranny has been sitting a while, but looks very clean inside and out) and then switch to this. I have four quarts on the way to the parts store, should be there tomorrow.
Here's the sales pitch on it:
"Synchromax is a manual transmission fluid that increases performance and the life of your equipment. It improves shifting, reduces gear noise and increases power transfer to the wheels. It also lowers operating temperatures and provides outstanding wear protection for longer transmission life.
Synchromax is recommended for manual transmissions that specify an automatic transmission fluid. It’s also ideal for 4×4 transfer cases and motorcycle gear boxes. Synchromax is fully compatible with all types of friction materials. It provides excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers.
Synchromax is formulated with Royal Purple’s proprietary Synerlec technology for unsurpassed performance and protection."
from http://www.royalpurple.com/manual-transmission-fluid.html
I've had good luck with Royal Purple products in the past.
