TWeatherford
When I put the 6.9 (which originally had a C6 behind it) in my 94, I swapped the plate that connects the transmission to the block. Once I got both off (the one off the old 7.3 with ZF5 and the one off the 6.9 with C6), I held them up to each other and am 99% sure that I observed they were exactly the same and that was wasted effort on my part. Can anyone confirm this for me?
I'm trying to figure out my Cummins conversion, as the Cummins powered Ford I have now has a C6 in it, so maybe I can use that adapter to hook my ZF to the Cummins, if I can find a flywheel, clutch, and starter setup that will be compatible.
