Zf5 swap and engine swap
Philip1
Northeastern Nevada
Yes I installed a tee on top of the ip
not the greatest picture but it shows the result
cardana24
Virginia
Thanks man . Do you know what size barbed fittings I need? Are they 1/4, 5/16, 3/8? I’ll need to guy some stuff to make it work.
cardana24
Virginia
1/4 npt and I used 1/4 fuel hose
Yeah I just got back from Lowe’s. I’ll post a pic of the stuff I got and I’m sure you can probably get this to work with less fittings but this is what my local Lowe’s had. So from the pump I got an 1/8” nipple, then I got a bushing that goes from 1/8 >1/4, then I got a 1/4” threaded T, then I got two thread to barb nipples. I’ll put it all together tomorrow and post a pic, I hope it’s not too tall.
cardana24
Virginia
Does anyone have the tq spec for the 5/16” 12 point bolts that hold the pump to the timing gear?
cardana24
Virginia
What did you do with the return line coming from the fuel filter to injector? Did you put a barbed “T” in that to be able to tie it in to “T” on the top of the injection pump?
cardana24
Virginia
I got the return lines routed this weekend. Next is putting the exhaust and turbo on.
cardana24
Virginia
Can anyone confirm where these wires terminate on the gp controller? Does the glow plug harness terminate on the top post of the relay? Then the smaller black wire with a ring terminal terminate on the front corner of the controller?
