ZF5 Reverse Question
02x72
Des Moines, IA
My brother just picked up a 94 F250 and its having an issue going into reverse, where it will grind and be hard to get into gear. The PO had done a conversion from an E4OD with new clutch and single mass flywheel. Where should I start looking, I'm not too familiar with these transmissions
BioFarmer93
OPEC Hater
Jacksonville, Florida
Before you put it in reverse, put it in second, then real quick put it in reverse, clicks right in, no grind. Go ahead, ask me why I know this..LOL
This is a very common problem with the zf. Another way to do it, is keep pressure on the shifter handle as you ease the clutch out. When you do this, sometimes the shifter will move a little further and when it does this, you have avoided a gear grinding episode.
The next thing you will notice is reverse is very fast, really too fast for anything except a empty truck. If you have 4x4, you will find yourself using low range when backing loaded trailers.
IDIDieselJohn
0-60....eventually
Ottawa Ontario
X2 on the 2nd gear, then Reverse trick.....ask me how I know..... LOL
377k miles on a ZF, grinding reverse for many many years, you learn lots of little tricks :D
RLDSL
Diesel fuel abuser
Arkansas
If bobbing between gears won't do the trick, check clutch adjustment. since a smf was put in, spacers may have been left out, too many put in, or simply the brand of clutch being used may not want to play nice, so an adjustable clutch rod may be needed. Clutch should begin to release about an inch from the top, and should begin to grab about an inch off the floor. If not falling about in that range, then go to Napa and blow about13 bucks on an adjustable clutch rod
93f250idi
strokin
cadiz ky
The second gear trick and the letting out the clutch a little bit trick have always worked for me. If one don't then try the other!
02x72
Des Moines, IA
Thanks guys, the going into second things seems to be working, but there also seems to be too much play in the clutch, so an adjustable clutch rod is gonna be installed
G. Mann
Phoenix, AZ
I have the same problem on my F450/ZF 5 . Found there is a reverse lockout tab that keeps you from catching reverse instead of 4th. Also found that that tab gets damaged or slips out of position when the top cover is pulled and that the spring that holds the tab gets out of position or simply falls into the trans. Result in any case is it's hard to "find reverse" since the shifter doesn't locate it's self properly.
This might be your case. Check clutch release function and all the other things suggested as well.
G. Mann
Phoenix, AZ
Check under the dash on the condition of your clutch rod where it attaches to the peddle.
IF that pin is worn, your clutch peddle movement isn't pumping enough hydraulic fluid when you push it, so clutch won't release properly. There is "some adjustment" at that rod, but the pin doesn't get lubed and there is a plastic bushing that "goes away" which loses clutch travel. Check that.
