alienturtle
Human
Hey guys. I have run into another snag. Since i put the ZF5 speed behind my cummins it has been making some nasty noises. I just got it all apart and 3 case bearings need to be replaced. Both counter shaft bearings and the main shaft output bearing. The 2 counter shaft bearings seem to be the same and i pulled this number off them SKF EK-2580-26-CL7C and for the output shaft bearing on the race it had TIMKEN 28521. I had this tranny apart once already for the same noise and replaced the input shaft bearing and little pocket bearing behind it thinking that was going to take care of it. My ? is where can i get these bearings via these numbers. It cost me 100$ for the first bearing and 1 seal from a tranny shop so before i go back there i was wondering if you guys could help me find these other 3 bearings. THANKS in advance.
