ZF5, B injectors, Air Cleaner Housing, Return Line kit, etc
Michael Dimock
Grass Valley, CA
Cleaning up the last of the IDI parts that I still have.
Torn down ZF5-42 diesel 4x4. Needs 2nd and 4th. $150
Set of 8 used B code reman injectors off a running engine. Truck had around 140k when they came out, but I have no idea when they were done. Sold as cores $100.
2 new Delphi injectors kept as spares. $40 each
Factory 6.9 air cleaner housing with soup bowl removed. $30
New, early style return line kit. The bag is slightly open, so might be missing a few clamps, but otherwise complete. $20
2 new oil return grommets and 1 exhaust down pipe gasket for the early Banks idi turbo system. $10
I'm not on here much but I will try to check in regularly. Thanks.
Alleycat
