alienturtle
Human
I want to start out by saying i take no credit for this at all. hesutton is the one that showed me this so all Thanks goes to him! I just like to document things ;p
All you york people out there know that checking the oil in one is a pain. In my case its even worse due to where i have it mounted and the intercooler pipe that runs right across it. So here is a couple pics of the same thing hesutton did to his to make checking the oil no more than looking at the side of the pump For those of you that have them mounted on their side or at an angle, looks like you are still stuck with the dipstick method
The york manual HERE gives different oz of oil and the height level in inches of the oil. From what i have been reading the 12 - 14 floz seems to be the winner for people using them as an air pump. 14 oz of fluid sits 1 11/16in. On my gauge just a little below half would be 14oz and a little over half would be 16oz. That way if i ever forget the check the thing and it drops below the bubble i know i still have plenty of oil in it to run. You can run as little as 6oz of oil in these. Now thats as an original a/c so i wouldn't run it that low as an air pump. My sight glass came from grainger It is a 1/2 NPT. The tap called for a 23/32 drill bit. After drilling and tapping the hole i stuck my finger down in there and felt a good amount of shaving. The bottom plate was leaking anyway and the gasket was rock hard! So for safe measure i pulled the bottom off and made sure it was 100% clean. Made a new gasket for it and put her back together.
A couple pics of the inside. Cute little pistons ;p
