This is something that I've wanted to do since before I bought my truck. I thought I had a source lined up for 400 gal a year, but the guy set it aside for me last year, and someone else showed up an hour before I did and hauled it off... The guy still had another 30 gal or so that I got, but now I'm back in hunt mode.
All of my info to this point has been what I have READ (not tried) off of the infopop site. I can buy a 10 plate HE for less than $100 that will mount in the engine compartment, and should supply enough heat for 9 months out of the year. The gell point for WVO will vary a LOT depending on what the original stock material was. I've got some oil from last fall that didn't solidify until it was near 20 degrees outside. I've got other oil, that solidifies at 50 or 60 degrees, so you always want to test your stock. If you blend, then my plan is to stick a clear pop bottle of my blended fuel in the bed of the truck so that I can have a visual check of what's happening in my tank. Allow the oil to settle for a month or two, and then drain the thin oil off the top and use it for colder weather, and use the "grease" during the summer months. This works well when it's 40~50 degrees outside. Warmer than that, I think it all just mixes together because it's all a liquid.
When I fill up, it will get dumped in the tank, and refilled with the new stuff. Also, a lot of guys are adding 5% to 10% gas to their blend, and that is lowering the gell point of the WVO a LOT!!!! More gas in the winter, and less in the summer. More than 15~20% is causing problems even in the winter, but 10% APPEARS to be safe year round. I've seen some video (we all know how trust worthy that is) of a guy who claimed he had a high trans fat percentage WVO (almost grease, about 50 deg gel point) and with a gasoline blend (I can't remember if it was 5% or 10%) it turned to a liquid when the gas was added. This was done outside in supposedly 20 deg weather. I have no idea what the temp of the grease or gas was, or if the blend turned back to a gell after a few minutes when it cooled to ambient temps. This is an experiment I plan on doing myself using some .5L water bottles, the fridge, freezer, and a deep freeze. My first experiment will be to put gas in the water bottle and leave it in the drive for a week to see if it eats through the bottle. I don't think mama will be happy if that happens in her fridge....
A heated filter is highly recommended because that's the point that will clog up first when the oil starts to gell. I would like to install 2 golden rods (one for blends, and one for D2), but I never took it to the point that I figured out what valves to get and how to tie them back to my fuel selector switch. I also planned on switching over to an electric fuel pump, but since my source really didn't come through, I've stopped spending money on it for now. Other than that it was just a matter of remembering to switch over to D2 a few minutes before stopping so that your entire fuel system has D2 in it when you shut down. The WVO will for a plastic coating on most metals when it just sits there. This process is excelerated in the heat, so having a fuel system full of WVO sitting in the parking lot all day in the middle of August is less than ideal.
For what its worth, that's my 2 bits,
Mark
