WTB
catbird7
PA
Looking for lock slide mechanism for bullnose 1980 or 1981 F series (F100 thru F350). These are the only years that utilized a slide lock for the doors. I need one for driver side (any color).
Also looking for factory 4spd shifter knob for dent side (1973 thru 1979).
THANKS!
Thewespaul
Bulverde, Texas
The bullnose is a 81, do you need the locking assembly from inside the door panel?
catbird7
PA
Your photo of bull door panel is an 82-86. I need lock slide from 80-81 (see attached pic).
Also, your photo of shifter knob is a bump side 67-72. It might fit however I'd like to find one from a 73-79 with shift pattern.
Thewespaul
Bulverde, Texas
Well dang! I’m thinking these doors have been replaced then, the trucks titled as an 81, but has body panels from three trucks that I can see. There’s some aftermarket shifter options that I’d lean towards if I needed a shifter for that truck, I think hurst did a rerun of some of their older style shifters that would be pretty period correct for that truck. Since the bullnose door is the same could you put an 82-86 door panel on?
catbird7
PA
Surely someone out there has an 80 or 81 F.100 thru F350 with an intact driverside door panel? I only need that little slide lock mechanism shown in pic.
catbird7
PA
Just to report back on this, ended up finding NOS slide lock @ Dennis Carpenter.
Tyler9828
