WTB Rear Sway Bar Brackets
Giddy-Up
North Dakota
Looking for a set of the rear sway bar frame mounts off a 4wd. As far as I know they're the same on F150-350, 1980-97
FarmerFrank
Blairsville, Pa
I ought to have a set on a parts truck, let me take a look later and see if they are any good
jhenegh
Truck Still Earns its Keep
Deerfield, WI
Count me in as needing a front and rear set as well. 2nd in line please!
FarmerFrank
Blairsville, Pa
Darn, I know I walked past that truck a couple times yesterday. Ill look tonight at them
jhenegh
Deerfield, WI
Ya, I've found Banks 48899 new for the front, but I haven't found much for the rear. Probably pretty easy to make, but there's only so many minutes.
Giddy-Up
North Dakota
I briefly looked for them new but didn't think to check with a dealer.
I have a set of the factory mounts for a dana 60 front I'm not going to use. Throw me an offer if that's what your after.
jhenegh
Deerfield, WI
F3TZ5L499A is the rear bracket #. Looks to be a discontinued part most places
FarmerFrank
Blairsville, Pa
One parts truck didn't have them like I thought it did, only have one set that's on a truck I'm putting together. Let me check one more parts truck at the farm, it ought to have them.
You guys want just the bracket that bolts to the frame correct? Not the arms that attach to the sway bar
jhenegh
Deerfield, WI
Yep. Frame bracket for me. Not the link down to the bar.
Some good pics and measurements would be great too if you don't have a 2nd set I could buy. I could probably make some easy enough then.
Have parts here...2 folks are looking...be specific to what parts you need and if fronts or rears cause I have both in 4x F350 in stock.
lewisstevey7
