im not sure on that one federal mogual has one for a good price as well you can get locally and icanfix and others on the board use mahle and summit offers there stuff at a good price im gonna be using them as well but ive never heard of that one before doesnt mean its bad i just havent heard of them ive been looking for parts for mine for a year now and im piecing it all together
well hypermax is good mahle is good federal mogual is good typ4 offers some stuff as well what are you trying to do and i might be able to help more i have a list made
Man I'm just trying to get this thing running again. At this point I am doing the bottom end as well, minus the oil cooler. So I at least need rings and bearings and gaskets. I will put a new oil pump in. Pistons will be replaced upon further inspection. Need to determine whether the bores are in spec and can be honed or I need to go oversize.
Towcat has the best ring package available but its gonna be costly. He uses them in his fleet of idi tow trucks. Russ does know of a very good bearing set too. They are better than the oem Mahle too. You may just need rings and bearings. DO NOT REPLACE THE OIL PUMP... The Melling aftermarket is nowheres near as good as the old oem one your useing now. Just ask Russ what he found on a new Melling.. What a piece of chit it turned out to be... Save yourself some money and do whats needed when you have some measurements on the bores and wear on the pistons.... But do install a set of studs. They are much better than a new set of stock head bolts and they are cheaper than oem head bolts too.
