WTB 1984 f250 foot pedal assembly
oworm
Indianapolis IN
The splines are gone on mine. I need a replacement. Truck is a 6.9 IDI but it's my understanding that ford used the same assembly in all f series from 80 through 87
he needs the clutch pedal shaft. it is the same from 83-91. the pedal bracket is different due to the fact it moves the pedal position.
madpogue
Madison, WI USA
You sure it's the splines on the shaft that are gone? Usu. it's the splines on the arm with the pushrod pin that pooches out. Or poss. the arm for the pedal itself. IIRC, the pushrod arm is still available.
