Let's divide and conquer! All this talk of slow cranking is valid, but let's first make sure there is fuel to the injectors. Loosen ONE injection line at the PUMP end, and hold a tissue around it. See if it wets. If it does, then we know at least that fuel is exiting the injection pump. Once you have verified that, then do the line bleeding until you verify fuel at the injector. By now, your glow plugs have taken a huge beating if you did not disable them, so disable them before doing anymore key-on stuff. Once you verify fuel at the injectors, verify smoke at the tailpipe. These engines won't start on a slow crank, but they will smoke! Where there is smoke, there is the potential for fire. Once you have smoke, then look at glow plugs and cranking speed.
