Wont start-clutch interlock broken
zukinut
bristol tn
97 F250 with zf5 and 7.3 psd. The clutch interlock switch went bad, how do i bypass it. Truck wont start and is loaded with tools and materials and needs to get to the jobsite asap.
Please help.
for a quick fix, arc the starter solenoid on the fender. fat bundle of wires on the stud to the small skinny stud. have the ignition on and the trans in neutral with the parking brake set.
for a more permenant fix..... the clutch interlock is on the master cylinder pushrod itself.
the cruise control is there too, so you'll see four wires.
if you're stranded, you can always jump the solenoid on the fender, just make sure you're not in gear.
i just looked in my alldata, the wire you want to jumper is the red with light blue stripe. ......this is a excerpt from a post I did for the IDI section, it very well may be the same wire color combination for the PSD.
lewisstevey7
