WMO Filtration Setup - my version
mankypro
Learning Slowly...
Boulder County, Colorado
As I've partially detailed elsewhere I'm going to do the following (in order) to filter my WMO:
1. "Dirty" 55 gallon WMO drum - placed about 4 ft off the ground on a pedestal made of 4"x4"'s and 2"x4" - it will be wrapped with one of these: http://www.drillspot.com/products/63576/Electro-Flex_DH-55-115_Drum_Heater (or a less expensive facsimile) and I may very well use a 10 micron sock style filter to get the bigger stuff out of the oil as I pour it.
2. Out of the side about 1" off the bottom rim I will place a 1" pipe fitting, soldered or welded in place.
3. at 90 degrees from the outlet pipe mentioned in #2 I'll put some sort of drain **** valve at the bottom rim of the barrel so I can drain out settled water and other yuckies separately.into a bucket.
4. off the pipe in #2 I'll braze in place a ball valve turn off
5. another few inches of pipe then a psi gauge.
6. A Lowes or Home Depot 5 micron whole house filter housing and filter:
http://www.lowes.com/lowes/lkn?action=productDetail&productId=89374-43568-WHCF-DWH&lpage=none
http://www.lowes.com/lowes/lkn?action=productDetail&productId=149007-43568-WHCFWHSW&lpage=none
7. Few more inches of pipe and a Goldenrod water separator:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_350494_350494
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_363415_363415
8. A few more inches of pipe then a flexible hose to drop into a 420 gallon tote or another 55 gallon drum for storage.
*I'm wondering if, given that the oil mixture will be heated the gravity flow will be enough, or if I will need to add a transfer pump in line to push the oil through the filters. Would it be better to pull or push with it?
This guy is 6gpm:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_16818_16818
This one is 120v and a little bit slower:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200352045_200352045
Figure I could put a rheostat on it to regulate it's output?
Critiques etc, appreciated.
subway
be nice to the admin :D
York PA
pump are always better pushing the liquid and yes unless you can walk away from it for a day or two and just let it gravity drain i would add a pump. you get more out of you filters and it will go faster than a dribble.
unles the tank is open you might want to add a sight tube going up the side to see how much is in there.
otherwise sounds good....
discbrks
Columbus, GA
Why don't you add one of these to the top of your "dirty" 55 gallon drum to catch any of the big crud as you pour it in.
http://cgi.ebay.com/55-Gallon-Barrel-EZ-strainer-Filter-Biodiesel-SVO-WVO_W0QQitemZ260251543384QQihZ016QQcategoryZ57114QQssPageNameZWDVWQQrdZ1QQcmdZViewItem[/URL]
If that doesn't work, try ebay item # 260251543384.
MIDNIGHT RIDER
mankypro,
I suggest the first filter/housing in your line-up to be a GoldenRod housing with one of their stainless-mesh cartridges.
These are available in two mesh fineness ratings and are indefinitely washable and re-usable.
They also would be good as a first defense against big clumps of dead "algae", which is technically not really algae, but another family of organisms; algae cannot live in darkness.
mankypro
Learning Slowly...
I don't know if algae would live in WMO? In any case my fuel pickup has a 100 micron mesh pickup filter on it - should handle any clumps ok. Also the yarn filters aew like $3.00/pc the goldenrods are $12-14.00 a piece. I'd use the GR to separate water, not much else.
I wonder if a mist wash would work in wmo the way it does in WVO...
mankypro,
REM70
