Josh Carmack
Yes the timing advance is controlled via back-pressure. If you have ever seen the top of the IP removed, it has two solenoids, one has a lever which goes down into the governor section which is the shutdown, and the other is simply a valve that controls the amount of back pressure is seen by the pump. How that actually increases timing I don't know.
I do know that when you are diagnosing a no fuel problem, and you are unaware of the design it defies logic when you remove the top cover and find the solenoid that closes a fuel valve is good, but the solenoid that controls a mechanical linkage is bad. Until I learned it was the opposite of what I assumed when I opened it up I was confused as hell as to why the "fuel valve" was good, but I was getting no fuel to my injectors and I had a bad "advance" solenoid. Kinda had me scratching my head til someone I don't remember who told me I had it backwards.
