Sep 5, 2023 #1 Kdo58 Full Access Member Joined Sep 8, 2021 Posts 200 Reaction score 201 Location Puyallup washington Is this a factory wire? If so any ideas what it goes to? You must be registered for see images attach You must be registered for see images attach
Sep 5, 2023 #2 Nero HD Diesel nut Joined Jan 3, 2022 Posts 2,455 Reaction score 2,500 Location OR Ground, I believe for the RABS
Sep 5, 2023 #3 Kdo58 Full Access Member Joined Sep 8, 2021 Posts 200 Reaction score 201 Location Puyallup washington What the rabs?
Sep 5, 2023 #4 Nero HD Diesel nut Joined Jan 3, 2022 Posts 2,455 Reaction score 2,500 Location OR Rear Antilock Brakes System. If you've already deleted it, then you don't need the wire.
Sep 5, 2023 #5 X XOLATEM Full Access Member Joined May 5, 2023 Posts 636 Reaction score 810 Location Virginia... in the brambles Rear Anti-lock Braking System... I have the same wire on a Ranger...and when it works loose...the ABS light comes on... One aspect of my PM on the Ranger is to check connections... Last edited: Sep 5, 2023
Sep 5, 2023 #6 Kdo58 Full Access Member Joined Sep 8, 2021 Posts 200 Reaction score 201 Location Puyallup washington I haven't deleted it but the previous owner might have, the anti lock light on the dash is on all the time
Sep 5, 2023 #7 X XOLATEM Full Access Member Joined May 5, 2023 Posts 636 Reaction score 810 Location Virginia... in the brambles Try running it to ground and see if the light will eventually go out...
