bike-maker
In this next few days, I'll pick up more fuses and sacrifice a few to see how many amps the fans are drawing.
But for now, I'm taking Lotza's advise and taking a break for a while.
Would the highest current draw be at start up with everything cold?
As for the dash comments;
I drug my 84 out of a field where it had sat for 3 years with a 460/C6 and 3.55 gears. Knowing I wanted a diesel for towing my 5er around, I bought a 89 F250 with 7.3/ZF5 and 4.10 gears that had a in-cab fire for a donor. Long story short, I swapped the entire drive train out of the 89 into my 84, except for the transfer case and drive shafts. This included the manual steering column, thus the bricknose steering wheel. One of these days I'll get a nice aftermarket steering wheel for some extra bling.
So I searched for a slant nose diesel cluster with tach for about 2 years until I decided to just use the tach and speedo that came out of the bricknose.
Snowball effect commences, and voila - custom dash.
It's all made out of .080" aluminum sheet.
Quick rundown of the gauges;
Left of speedo - Auber pyro on top, boost on bottom
Right of tach, water temp on top, oil pressure on bottom
Across the top of this panel are indicators for turn signals, brights, 4x4, brake warning, low fuel pressure.
Moved stereo down about 1/2" so I could stack 3 gauges above it; 2 fuel level gauges (1 for each tank), and a voltmeter.
Then built a pod on top of the dash to house the factory clock and cover up the big hole in the dash.
In place of the factory clock (these are the ones LCAM asked about); vacuum gauge on the left, 3 air pressure gauges on the right for the on board air and rear air bags.
Up above all of that - above the rear view mirror (can't see it in the pics), I mounted an overhead console from an Explorer.
So now I can get more info than I really need, or get distracted enough to run into something, or both.
And finally, built another panel in place of the ash tray underneath the temp controls, which houses the cig lighter, and an air switch and regulator so I can adjust the pressure in the rear bags on the fly.
