I'll get the fans up and running, and try using them through this next summer, and see if I want to change anything. Like adding flaps or a controller.
Anyway, some more progress today;
Fans are permanently mounted up to the radiator.
Here's what they look like from over the top of the driver's side fender;
Here's a shot straight down so you can see how close to the engine everything sits;
Above pic shows that the "longer" motor (right side) actually sits back behind the power steering belt. In order to slide the assembly in place, I have to pull the power steering belt off, and also the sheet metal cover that goes over the larger fan (left side). The upper radiator hose can be kept in place. If I did it again, I would make the shroud thinner, which would allow the shroud to be pulled out without removing anything. Also note I have deleted the AC from my truck, although I do have a York compressor that I will mount in the standard AC compressor location for an on board air setup. The belt position on the York should be very close to the stock setup, but if it gives me problems, I was already aware of the ability to run a second bigger (thinner) motor to gain some more room.
To answer a previously asked question, the shroud is 2-1/2" thick + about another 1/8" for the vacuum line around the edges of it.
And on to the electrical side of things.
I already have a row of DPDT switches in my dash, so I am going to use one of them to control the fans. Switch in the up position will turn one fan on; switch in the down position will turn both fans on.
Years ago, I made a little electrical box to house the electrical components for my own headlight relay mod. Used a couple relays and some Wago parts - their some stackable junction/fuse blocks that clip on to DIN rail that I scored from my previous work (company that converted buses into high dollar motor homes).
I was hoping to just add to this box, but in my infinite wisdom, I made the thing just big enough to fit the components for the headlight relay setup.
Here's what it looks like;
With the lid on...
This was back when I had access to all kinds of cool equipment; iron worker, brakes, shears, tig welder. Now I'm just working with what I have in my garage, but in classic *********** fashion (thanks, OCD), I decided to have a go at making a second electrical box to house the components for the new electric fans.
Broke out my last scrap of .080" aluminum and whipped out a box with a hammer, vise, and some good ol' redneck ingenuity. Didn't turn out half bad...It will just barely fit next to the radiator; in between the core support and the driver side battery.
Here's as far as I got tonight; box built, components installed. Just need to bolt the box in place and wire the whole mess together.
You can see part of the lid in the background.
And on a side note, I was digging through my aluminum pile, and found this guy:
It's a custom aluminum racin' bracket (even has speed holes in it) I made way back when that bolts to the fuel filter tower to mount a coolant filter off of it. I ended up mounting the coolant filter on the inner fender, and don't have a use for it. Any of you NW guys that are willing to swing by my house in Albany can have it...
