Windowed Block on TDI
SeeYa
OB Vendor/ DP-Tuner
Asheville,NC
Max Power said:
Yikes is that yours? What was the cause?
This is what we think happened. One day back a while I had to get into it a little(ok alot) to avoid getting rearended. The car hadn't run right since. It must have bent the rod brought on by overboosting. Over time it just couldn't take it anymore and went. You can tell by the pic of the piston conection that it was a clean brake. Sure was alot of debris when Jody started taking her apart. Rod was twisted pretty bad. No worries, new block,and engine are on the way. Among other things. :santa:
Diane
REM70
