will not stay running
metalman
calgary alberta
have a 06 duramax lly that will start but dies after couple sec. like you turned off the key. have no interior lights radio cluster etc. except the seats. checked all the fuses .think might be bcm ?
ameristar1
The One Blue Thing
Steger, Illinois
Check for any loose harness connections, and make sure all your grounds are intact. When did the problems start?
metalman
calgary alberta
bought from an auction so don't know to much about it.checked all conections have had them all apart no corosion ,checked fuse all good,
ameristar1
The One Blue Thing
Steger, Illinois
Ok, I was trying to avoid this but pull the computer and check it against a new one. I don't like to spend the money if it is a simple thing. Has the truck been in an accident or had flood damage?
