Why so hot??
SPR1NK
Stevensville, MT
So the new engine my dad and i put together for his truck is running hot, crazy hot
220 cruising empty flat ground, saw 250 the other day goin up a slight hill and had to pull over to let her cool
Tried replacing the thermostat and water pump, no change still averages 220
Yesterday he took out the thermostat, now its averaging 180 degrees
What would make it run so hot?
Selahdoor
Index Wa
You answered your own question. Wrong/bad thermostat.
You can buy a brand new tstat, and it can be bad. Or you may be buying the wrong tstat.
SPR1NK
Stevensville, MT
Both thermostats have been motorcraft thermostats that we picked up at the dealership, they look exactly the same as the one thats in my truck and mine doesnt have a heat problem
I wouldnt let him buy a cheapo thermostat from the partshouse after the issues i had in my old 6.9 running a cheap thermostat
SPR1NK
Stevensville, MT
Also when its running that hot if we hop out and use the no contact thermos on the rad, its usually 190ish at the inlet and 80-100 at the outlet, thermo says 220 when we point it at the block, changed gauges to make sure we didnt have a bad gauge and still says same temps
dgr
sac town
Sounds like you're doing everything correctly. Any chance the t stat is in backwards?
Where is the temp sensor? Mine is above the oil cooler and consistently reads 5 to 10 degrees above t stat opening temp
What about the radiator being plugged or the bottom hose collapsing? With the numbers you have, it sure seems like a water flow issue. I the think removing the stat eliminates the plugged rad... Hose spring in place?
saburai
Swap the thermostat. Then swap it back. That would give me a pretty definitive way of ruling out the thermostat.
SPR1NK
Stevensville, MT
Temp sensor is where the factory temp sensor was, hoses arent collapsing, spring is in hose
What would swapping thermostat then swapping back tell me if there was already no change in temps when we swapped it out the first time
SPR1NK
Stevensville, MT
How much of an effect on temps does timing have on these? It is super hard starting when cold after dad had someone else adjust the timing, maybe i need to get my timing meter on it again?
The_Josh_Bear
Western WA
That is a huge temp swing for a rad, is the radiator plugged up?
If that's not it then maybe the water pump is somehow not spinning or something. Do you have flow through the rad when you take the cap off and watch as the engine idles?
It's far easier to boil a tstat than to swap them all over the place...just verify it does its job and then you'll know for sure. Should open about 1/2" at 212* IIRC.
Good man running only motorcraft t-stats!
The_Josh_Bear
Western WA
Retarded timing makes them run hot but unloaded you'd really never notice.
saburai
That would be easier. I guess I need to tie my thinking cap tighter. Or maybe loosen it:confused:
SPR1NK
Stevensville, MT
When we opened tye cap and started it all we could see was the antifreeze slowly rising up the filler neck until it started spilling out
It isnt factory rad, its a champion aluminum one if that matters
