Which clear inline fuel pre-filter?
MtnHaul
California
Finally changing my fuel pump but want to add sufficient filtration before the frame rail mounted pump. Really don't want to go with a header & filter setup and prefer the inline. So I'm just wondering what people have found that flows enough fuel and doesn't clog quickly. The pre-filter on my Facet pump has not caught very much gunk but there is a growing layer of sediment at the bottom of the clear plastic bowl so I know I need something before the pump.
hacked89
Bucks County PA
Pre filters should be 20-100 micron and post filters 10 micron or less. You don’t want to go with header and filter which is what I do/would do but you can run a Walboro or any inline pre filter. As you said it’s meant to catch the big stuff from damaging the epump not the very fine particulates which is what post filter is for. I run header setup with 20 micron pre with water separator and 10 micro or less post.
MtnHaul
California
Now that's what I would call "Having plenty of room to work". Mostly I'm just concerned with the potential for damage when driving off-road, but maybe a small filter and header tucked high up. No lift on my truck so I would prefer not to have anything protruding below the frame.
hacked89
Bucks County PA
I agree with you, I set it up like this because it’s not my trail rig. If it was going on trails I would re engineer it to not be below the frame.
quickster
S Carolina
What kind of fuel line setup would replace the filter and hardline to the pump. That would free up a lot of room up top.
12pilgrim
Nashville
Wow... that is beautiful. Are those metal fuel lines?
The_Josh_Bear
Western WA
I have a single header and baldwin spin-on setup on my frame rail, similar to @hacked89 but I tucked mine above the transmission skid-plate so it can't catch on anything. It doesn't hang down very far but it's still well above the skid plate, so nice and safe unless you're high-centering at speed. At that point you have other problems!
Ruffnek7tree
Northwest
I'm going to set mine up much how hacked89 did, but much less clean lol.. I'm going to use a WIX 33972 filter before the first filter, it's a 50 micron rated filter, does a good job of keeping the ball bearings out of your pump, and it's cheap to replace, like $10 IIRC
The_Josh_Bear
Western WA
For funsies I took a picture of my fuel filter poking below the frame.
It's pretty well-protected, and serviceable.
REM70
Staff online
