exhaust manifold? if so where? is back of driver exhaust manifold good?
no turbo.
just wanted the gauge for towing purposes. does the manifold need to be removed?
thanks
Exhaust manifold between cylinders 6&8, don't have to pull the manifold, just put a big glob of grease where you'll drill, the shavings will collect in the grease.
I just opened my hood and I was able to fit my drill in from the top. I'm sure if I tried from underneath, I would have been cussin as soon as a hot shaving dropped down my shirt
Real easy to do. Maybe use a center punch and tap your manifold with it first to keep your drill bit from wandering.
