my85ford
ok Ive decided to put in arp studs in my truck where the best place to get studs for the 7.3 idi any help would be greatly appreciated thanks
ARP does not offer a stud kit for our motors but... They offer a 7 inch stud. The part number is AR7.00-LB... This is a stud 1/2 13 threads on the bottom and 1/2 20 threads on the top. The nuts are ARN12-1 and the washers are ARW78N. Be careful when you install them. The instructions are to torque them tight and loosen them up 5 times. Thats a lot of work. What your doing is decreasing the friction between the threads, nut and washer. It does make a big differance in final torque. My studs and nuts moved about 3/4 turn when I was done... They also sell a great molly lube which will reduce the friction too. In their instructions they show the differance in 30 wt oil and the molly lube. The torque is 130 lbs with 30 wt oil and 100 lbs with the molly lube. Thats a big differance when you do 34 studs. And doing it 6 times is lots of work. Use an old head gasket for this torqueing and loosening. What I did was I used a old head and a used head gasket. Installed all the studs and tightened them. Then loosened them 5 times. Its a lot of work but like I posted... Its well worth it. All this info in on their web site too. Another member didn't do this and nothing has happened with his final torque. He boosts high and hauls heavy but... I go that extra mile for my sanity. I can't afford a breakdown on the road with 1/2 a million dollars worth of hosres in the trailer going to a show. We have a time schedule too. When you call ARP they wont have any idea what your talking about when asking for a stud kit for our 7.3 idi motor. They might even try to sell you a 7.3 psd kit so be careful about that too. My invoice number was 0487144-N in 1-25-08... Salesman number was 9999... Hope this helps you get the good stuff....
