firemedicmonkey
Erie Surf and Ski
Below is the story of my trip from Cleveland Oh to Bloomington IL to pick up my first diesel truck. The truck which I found on ebay: 1993 F-250 XLT 4x4 Single Cab Long Bed.
Well wow ok. Here is the story of my weekend. I left Cleveland after class and headed for Valparaiso IN, (45 mins east of Chicago on I-80) I was driving my dads Dodge Shadow 2.5l Turbo 5-speed. The plan was to drive to Bloomington IL on Sat and pick up the truck drive both back to Valpo and then tow the car back to Ohio. Well the clutch let go and took out the tranny Friday night. Luckily I got to Bloomington the truck looked about as it was described. It was -1 deg F without the wind chill the truck fired right up. I checked out that the little things listed in Mels tech article except checking the coolant, didn't have the opportunity. We loaded the plow in the back of the truck and headed for Valpo. Made it back to valpo with out a problem running 75 mph @ 2500 rpm and plenty of power to spare. I got to valpo and the trailer lighting plug wasnt working. While I was working on that I noticed that the rear-tank was leaking fuel. Luckily I only had $20 in it and had run most of it out. Still ended up covered in fuel though. Sunday evening I headed for home.
Plow was loaded up car was loaded up and trailer was hooked up. Some air in tht tires and a fuel front tank of fuel and I was on my way. It was running good down the highway I was running about 70-75 mph @ 2500 rpm the whole way. Every time I would stop I would smell some strange smell but I could not figure out what it was. Also there was a hazy like smoke the headlights were lighting up. I had not idiot lights on and all the gauges were good to go. Then the water in fuel light started flickering and the O/D light had been flickering the whole trip. The truck was still running strong so I just prayed hard to mister Ford and kept the hammer down.
Then I got about 70 miles from my exit on I-80 the fuel gauge was reading empty but I only had about 225 miles on the tank so I figured I could make it the 5 more miles to the travel plaza. yeah well that didn't happen. I ran out of diesel about 3 miles from the plaza. (I didnt know that at the time.) Thank goodness for roadside assitance. So while I was stranded and waiting for the tow truck I noticed the front of the trailer was covered with an oily substance, that led me to the rear end also covered in an oily substance, and continuing forward the majority of the underside was covered in the oily substance. I traced it back up to the transmision that also had this oily substance on the bottom of the pan. The gasket on the pan was also soaked with this oily substance. I then asummed that it was the tranny leaking. But from the amount of missing fluid, I thought the tranny would have been acting up slipping ect, but no real sign of it. I checked the tranny fluid cold (still waiting for fuel) it wasnt extremly low but I also smelled it and it smelled very similar to the wierd smell from earlier.
So the tow truck showed up with unleaded after I told the operator 3 times i needed diesel. so the tow truck towed my truck and trailer the 3 miles to the service plaza and I filled the tank. Then the truck wouldnt start or crank. It sounded like a stuck starter. The tow truck driver got out a hammer and hit the starter and i got it started. I never shut the truck off again. I drove it home and made it. Something in the drive-train didnt feel right when I was backing the trailer in. So then this morning I come out and the starter is still not working. So I climbed under and found that the main power wire from the battery was loose. Tightened it up and it would crank and crank nothing doing. So my dad had the idea to use some starting fluid, I raised protest based on an article that I read either on this site or another one. But he did it anyway the truck fired right up. So been driving it all day no starting or running problems, I check the tranny fluid and it wasnt low but the whole length of the pan gasket is covered in the oilly substance. The whole under-side is still covered from tranny back in the substance. I have laundry list of things that I think need fixed and tweaked on the truck and will be posting about all of those in another post but I thought I would vent about my weekend from hell but I would rather go through that then go through owning another chevy! :draw
