Wheel nut force / torque
Rainer1965
Bottrop, Good Old Germany
Hi all,
anyone here who knows how many Nm torque I need to apply on the wheel nuts on the E350 econoline 1993?
8 hole wheels , dually rear
Liebe Grüße
Rainer
LCAM-01XA
my very own hell
Pickup trucks call for 140-200 lbs-ft, translates to 190-270 Nm. You most likely have the same 9/16" (about 14mm) fine-threaded wheel studs, so the same torque should apply. If in doubt pull the chrome cover off one of the lug nuts, the torque numbers will be stamped on the front face of the nut, the writing wraps around the stud kinda.
Lance
