What's this tractor worth?
DBogo
Upstate NY
thats quite a few hours on that tractor and it looks like its been put through its paces
Duke
PA
My feelings exactly, although I thought if I could get it cheap.......
PackRat
Buzzard Pilot
Kansas
Needs too much electrical work, for that opening price, let alone more. There is a reason that the key switch and fuse block are shot. Either they aren't properly protected from the elements, or there are serious electrical problems. If they aren't right, then what does the rest of the electrical look like?
Exhaust could be as simple as a gasket, or it could need a new manifold.
I wouldn't bid, unless I could go give it a once over, in person.
Duke
PA
I think you're right. It's the perfect size, HP and I don't need any implements.
He lives about 50 miles from me and sent me more pics.
I was thinking it was worth ~$5,000 in its' present condition. He says he wants ~$8,000 Bluebook say ~$10,000.
Ex. man is cracked & gasket is gone. He said the key switch has gone bad 3 times since he's owned it.
Think I'll pass.
Truckie
Pittsburgh Pa
Passing may be the smart thing to do. It sounds like it is the start of a problem child, and those electric gremlins are a pain in the ***. keep checking out the truck trader and heave equipment trader, you should be able to find something a lot better there.
mjstef
Big Sky Country....
Big Sky Country
Think I'll pass.
Kubota is good for key switches going bad but they are indestructable little tractors. Dad has a L2950 and i put a pushbutton starter on it after 2 switches. It has 7800 hours on it and runs perfect. I wouldn't be to scared of it.
If you're not against made in china stuff, I do have a source for extremely reasonablely priced tractors and maybe a local retailer if you are interested.
DirtFarmer
Think I'll pass.
I think your $5K is about right. I bought a very clean 40hp Case/IH a few years ago with 1000 hrs for $5,500. But it is only 2WD. I've always heard that compact utility tractors are good for about 4000 hrs, plus or minus...
DirtFarmer
Here she is. Check out the front of the hood: "US AIR FORCE". She used to keep the grounds at an air force base that was closed. Bought her at auction. :thumbsup:
Duke
PA
DirtFarmer,
Hey that's a nice looking piece ya got there!
Towcat,
Thanks for the offer!
I've seen all the different China tractors (Montana, etc.). I'm not convinced that they're a quality tractor. The prices are so low you just can't believe they could be any good.
DBogo
Upstate NY
if you really wanted one them cheep tractors i think the indian built mahindura is better then any of them chinese tractors
thamojster
