What years are the cabs interchangable?
Kelleyj1837
Delphos, OH
I have a 90 f-250. The cab and doors are rotted. What years will the cabs interchange from? I want to say its 86-96
justinray
Contributor
Cleveland, Tx
I'm fairly certain the will interchange from 83-97, the beds are different throughout those years as are the front clips.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Actually, I'm pretty sure you can go all the way back to 1980...although you'd need to swap wiring harnesses if you used a cab from a g@$$er truck, and you'd also want to use the harness from the generation of truck the cab comes off of (there are significant differences between the '83-'86, '87-'91, and '92-'94 harnesses)...
"if" you want to make this a completable project, find a diesel cab 88-91 or the odds of a quick completion will be difficult to insurmountable.
Brad S.
NW IA
Are you saying he could have a pickup like the car in the Johnny Cash song???
warhog
TN
It's a '60, '61, '62, '63, '64, '65, '66, '67 '68, '69, '70 automobile.....
Wicked97
Nebraska
87-91 is what will interchange.
80-86 has different wiring as does 92-94 as does 95-97.
Also the holes for things like speedo cables dash mounts and brake pedals etc are all different.
Best bet stay close to the same year and its a easy swap.
87 has a one year only wiring harness.
88-91 is plug-n-play.
anything else and you are in store for a serious adventure.
i've got the completed trucks but more importantly the scars to prove it.
Well lots of great info here..
There are physical differences in interior supports for pedals, steering and so on and wiriing differences between the years.
However physically the actual cabs are interchangable between 80-97 though as towcat and others have said swapping between years...can mean a world of hurt.
Best bet keep same model year as what you have.
If you are willing to do the work, anything can be done, in my personal experience it's always best not to have to do that work. KISS comes to mind Keep it Super Simple!
Good luck with whatever you choose, and please take lots of pics..
Oh and a cab swap...is not all that simple if you don't have the capability to lift it and so forth...sometimes cut/weld sheet metal is a better option, as you don't have issues with VIN #'s that way as well.
Hate to see problem due to VIN
JM2CW
Al
Kelleyj1837
Delphos, OH
its a standard cab. I picked up a 91 f-150 cab with no rust, good doors, good glass, and a nice interior. for $400 bucks. im just going to swap out the dash and wiring harness. I have nothing but time with this project.
JU57US
