NJGearhead666
Need a new vacuum pump. the last one I put in was a rebuild and lasted about 2 years. Is there a superior brand to go with? Or should I just bite the bullet and buy a motorcraft one?
Well the real question should be who rebuilt this and yes.. The Motorcraft pump will live much longer than what you just found out. Not to discredit other rebuilders but you get what you pay for most of the time. There really are some crappy rebuilders. BTW there is a plug in the back of the vacuum pump. Remove it and you can add oil. Many have saved their pumps by checking the oil in them. Some use STP. Others use other oils.
I think Im going to do an electric one when mine finally dies.
Caution if buying this pump. It has a different suction line direction to it and its drilled and not threaded for mounting. Ask if they have a drilled and threaded mount type for the idi with the V belt set up. With some modifications we can run the V belt vacuum pump on the serpentine belt set up by drilling out the threads in the mount. I did just that when I changed to run the serpentine belt on my 89 engine. Just added some extra vacuum hose to reach the system. BTW this vacuum pump is designed for the powerstroke engines but we too can use it. Just can't make it work on the v belt trucks or vans. but please call the seller. See if they have what you want or need. Dave has really helped many of us that purchased items from uhaul and found issues. They always made it right.There is a new vacuum pump on ebay, U-haul utechcenter. Gotta be a Motorcraft one.
This is the one you want if needed. $100 from U-haul.
http://www.ebay.com/itm/FORD-OEM-VA...Parts_Accessories&vxp=mtr&hash=item27d888cf90
