What oil do you use?
CB-GG
CEO of the doghouse
Florida
Delvac 1300.
Every 3500 miles. The truck tows regularly.
When I do the tranny...Amsoil Syn.
slumlord
Originally posted by gwhammy
Rottela in the motor, put RP in the trans and it sure made it go in gear and shift better! Guess I ot to change the tranfer case and front and rearend now. Kinda forgot them and got to many miles on the oil. Do you think RP would be OK in tranfercase or is it to heavy?
What is RP? My tranny is getting hard to get in gear in cold weather:confused:
Edit: must be royal purple:sorry:
CHarlan
Bulverde TX
Rotella T, every 2000-2500 miles.. I pull alot, and make lots of smoke. This breaks down the oil rather quickly.
BTowler
Short bus driver
San Antonio, TX
RP 15-40 in the motor, piece of **** Mobil1 in the tranny (changing that soon, having a bad shudder going into lockup since changing to Mobil1 :eek: :mad: ), changing powersteering to RP soon, same for dif.
hheynow
the misanthrope
SF Bay Area
Delo 15W40 in the engine. Change it every 4K
Red Line synthetic ATF in transfer case
Red Line synthetic 75W90 front & rear diffs
Mercon ATF in tranny
Geno
Noble Ok
I would run the schaffers or amsoil if there was a dealer in okla city, but I have this thing with paying freight on a product you will be dumping on a regular basis.
Geno
gotdiesel?
Fine Diner
New Hampshire
Just did the first service since I bought the truck used with 25k on it. Serviced the motor with Shell Rotella T 15-40 and man don't it stink:fart!!!! Will probably service again before the weather gets good and cold, and switch to Rotella t syn 5-30. The old man is gonna get his Amsoil dealer ship back so he can do his equipment with that, so I'll Probably switch to Amsoil through out in the spring:Thumbs Up
REM70
